  #11
Old 06-29-2022, 06:24 PM
swift12 swift12 is offline
just use anti groundloop feet? cheaper and lighter!
2022 dues paid gratefully. great site for help and info.
Old 06-30-2022, 09:45 AM
sblack sblack is offline
It ainít broke and doesnít need fixing
Scott Black
VAF dues 2021
Instagram @sblack2154
Old 06-30-2022, 03:40 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Happy Feet...and stay off the binders...
Brian Decker
RV-7 (Flying)
Old 07-15-2022, 08:14 PM
Tom @ N269CP Tom @ N269CP is offline
If your RV is oscillating side to side after touchdown, the source of the oscillation is likely the pilot. Just momentarily stop moving your feet and the oscillation will usually stop right away. Small movements...small movements. Unless you get hit by a strong crosswind gust, at which time you need to apply as much rudder and maybe some differential braking as necessary to keep it straight.
It's easy to overthink this.
I'm using a rocket-link on the tailwheel which removes most of the steering hysteresis. I really like it.
Kind regards,
Tom
RV-8 N269CP
O-360-A1A w/Hartzell CS prop on 100LL
Slick-IC+PMag ignitions
Steam gauges
EI UBG-16, FP-5, & MUX-8A datalogger
Garmin Aera 660
TruTrak ADI Pilot II (GPS coupled)
Garmin GDL39 3D ADSB-In
uAvionix Tailbeacon ADSB-Out
Infinity grip w/Matronics trim speed control
Reiff preheater system
TCW oil cooler air damper w/servo drive
AntiSplat oil mist separator
Mountain High O2D1 O2 system
Old 07-16-2022, 01:51 AM
KayS KayS is offline
Originally Posted by sibriggs View Post
I can't speak for all RV tailwheel pilots but for me, I say that ground looping an RV is something a pilot would have to work at.
My experience with traditional tailwheel aircraft compared to the RV9 has shown me it behaves very very nicely slowing down from a wheel landing.
Where other aircraft like the champs, birddogs, cubs, cessna 120/140s might spin at the least amount of rudder in-attention or sharp crosswind, the RV continues to track nicely where it was going. Prior to completing and flying my RV9 I worried a great deal about the dreaded ground loop. All the worrying was misplaced, I've had no problems with ground loops in the RV.
So my advice to anyone building or looking to buy an RV9 or RV7 etc.; they should get some time in one before worrying too much, or at least visit and talk to a tailwheel RV pilot/owner.
i'd like to second that. i also worried about ground loops in the 7 but i now have the impression that it's kinda hard to loop her. the other day i did some taxi tests at lower speeds at my home airport at night with no traffic.
you really have to work at it to get the tail around. but when she does your basically demoted to luggage.
i believe a 6/7/9/14 behaves more docile in that regard due to their relative wide wheelbase. so before you think about installing such aftermarket products, get a feel for your aircraft. before you try to solve a problem that doesn't really exists.
Old 07-16-2022, 08:49 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
First you can ground loop a C152 if you try hard enough or that incompetent to not know how to use Side Slip, Cross Control, aileron into wind to maintain directional control.
I take it this is a LOCKING tailwheel. NOT NEW... many conventional gear planes (tail dragger), espcially big ones, like DC3 or T6 have locking tail wheel. HOWEVER you still have to have speed control and use rudder and ailerons to maintain directional control (aircraft longitudinal axis aligned with runway with no drift) at touchdown and throughout landing roll. Brake dragging is a technique is really strong winds as well, but usually not needed.
No amount of locking tail wheel will make it a land-O-matic or as docile as a Tri-gear or nose dragger, due to CG location relative to main gear.
Weathervane will still be an issue. Also if tail wheel is not PLANTED it has little friction or grip the plane can auto-rotate into the wind and ground loop in srrong winds.
With that said RV's are one of the most docile tail draggers I have flown. RV's land like a slightly heaver faster J3 Cub. Every tail dragger has their quarks and personality. RV's are like a sweet puppy but can nip you if you are careless while playing with the pup, verses some tail draggers that are like a hungry Rottweiler and you have a pork chop tied around you neck. No tail dragger takes super human skill, but some have issues like small rudders or blanking of rudder and reduced authority of rudder in 3 point. Also poor visibility on approach in three point stance on ground is a feature of some TG's (but not the RV's). This adds a level of challenge. Short couple (distance from main to tail wheel) and narrow gear width makes some TG's less forgiving. Again not really an issue with RV's.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2021 Dues Paid
