Go Back   VAF Forums > Education > Photography
  #11
Old 01-01-2017, 01:58 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Good to know! I was wondering how to replace Picasa.
Old 03-23-2017, 10:46 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Any ideas to how to copy image address from iPad app? It keep trying to give me a hyperlink that won't work for posting
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2022
Old 10-01-2019, 10:15 PM
johnbright's Avatar
johnbright johnbright is offline
Default migrated from Picasa
Testing theory about Google photo accounts migrated from Picasa. Theory is links from migrated accounts will work long term whereas links from non-migrated accounts will stop working after some time.
This is a photo from a migrated account although this photo was added to the account after migration:
This is the same photo from a newer account not migrated from Picasa:
BTW both photo links ended in "... s1874-no" and changing that to "... s900-no" made the size better on the screen.
John Bright, RV-6A, N1921R, at FWF
O-360, 8.5:1, vert sump, dual SDS EFI EM-5-F
Z101 as a template, links
Old 06-24-2020, 02:44 PM
HunterH HunterH is offline
Default Remove ?authuser=0
Originally Posted by xavierm View Post
How to post pictures using Google Photos -
Go to https://photos.google.com/
Create a shared album by clicking the + next to the search bar
Select Shared Album
Select a picture for the album
Click "Create"
Name the album. I created a album called "VAF Forum Posts"
Click "Share"
Click "Done"
Add pictures you want to share to this album.
When you want to post a picture, go to the album and select the picture so it's full screen.
Right click the photo and select "Copy image address"
Click the "Insert image" icon then paste the saved image address in the field. It will be a long link.
My image doesn't work when I follow the exact instructions BUT I deleted the end of my link "?Authuser=0" and it worked. Probably something to do with the share settings of the album, but again I thought I did everything right.
URL originally: "lh3.googleusercontent.com/pw/ACtC...=w1303-h977-no?authuser=0"
https://lh3.googleusercontent.com/pw...-no?authuser=0
URL when it worked: "lh3.googleusercontent.com/pw/ACtC...=w1303-h977-no"
Old 06-24-2020, 02:46 PM
bkervaski's Avatar
bkervaski bkervaski is offline
Doug will be enabling image hosting on the site shortly, stay tuned!
N196 RV-14A #140376 (Flying) 2019 Bronze Lindy
N169 Carbon Cub EX-3 (Finishing)
N15Z RV-15 (Waiting ... impatiently)
Old 06-24-2020, 06:56 PM
bhester's Avatar
bhester bhester is offline
Default Exactly right
[quote=HunterH;1441632]My image doesn't work when I follow the exact instructions BUT I deleted the end of my link "?Authuser=0" and it worked. Probably something to do with the share settings of the album, but again I thought I did everything right.
You did, they recently added that extra at the end and what you discovered is the answer to the problem.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2021 VAF donator - alot better than any magazine subscription
Old 09-03-2020, 10:18 PM
rv6n6r's Avatar
rv6n6r rv6n6r is offline
Using the instructions in the OP I wasn't able to get google photos to show up. However in this post:
Originally Posted by BillL View Post
Here are some more options for resizing.
https://sites.google.com/site/picasa...nk-to-an-image
there's a bit about editing the end of the url in various ways, and after playing around I was finally able to do it by changing
[long url]-no?authuser=0 to [long-url]-no-tmp.jpg.
Also it doesn't seem to work to use the (shorter) link you can get by selecting "Create link" on the google photo, I had to start with the long link from right clicking the photo per the OP then edit the end of that.
EDIT: Well, that didn't work either. At first it did but after a few days my photo dissappeared from VAF.
However I found this which seems to work fine: https://www.labnol.org/embed/google/photos/
Randall Henderson
RV-6 / O-360 / CS, 1600+ hrs, 1st flight Sept. 1999
Outstanding Workmanship OSH 2000, Craftsmanship award AWO 2000
Airport committee chair & AOPA ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Last Donated August 2022
Old 10-05-2020, 11:32 AM
mchargmg's Avatar
mchargmg mchargmg is offline
Default Embed google photos
Hey all,
I have been using this little website to help with google. It is pretty easy. You go to google photos, open up a photo you want, and click on the create link option under the share icon. You copy that link, paste it into the embed google photos, and it spits back a "direct image link" you can copy and paste into VAF.
As an example, we took a night flight last night, and here is the Sabrina Lee getting ready to go back into the hangar. All I did with this photo was resize to 800 pixels wide when I posted into VAF. You do that by changing the final =w2400 to =w800 in the link.
Blue skies
Geoff
Geoff McHarg
2022 dues gladly sent
Old 10-05-2020, 08:14 PM
donaziza's Avatar
donaziza donaziza is offline
Hi Geoff, I'm reading this with great interest as I've always been picture challenged here on VAF. And I am therefore, as you've probably surmised, a computer idiot. Could you please help me with this part of your post
(paste it into the embed google photos, and it spits back a "direct image link")
as I don't know how to find it.
Thanx much
Old 10-06-2020, 05:59 PM
FinnFlyer FinnFlyer is offline
Default You can now attach pictures
After you click "Post Reply", click on the paper clip next to the smiley face.
That will let you upload a file (for example a picture) from your computer.
Finn
Click image for larger version
N214FL RV-4 Mazda 13B Renesis First flight 20 Feb 2021
N46AZ RV-3B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
