  #21
Old 12-03-2021, 08:35 PM
Northernliving Northernliving is offline
Originally Posted by moespeeds View Post
For the guys running fixed pitched props with a 360, what kind of cruise speeds and climb rates are you seeing?
Anyone running a 3 blade FP?
Asking for a friend.
Putting a FP prop on a plane with a performance envelope like an RV Is like driving a corvette stuck in 3rd gear. Sort of fun, but you sure are missing a lot.
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
New Superior IO-360-B1AC2 w/Hartzell Composite CS
RV8 - #83313 - Under Construction (sort of!)
Old 12-03-2021, 10:18 PM
gasman gasman is offline
Placing a heavy c/s prop on an RV 3, 4, 6, 7, or 8, makes your RV handle like a dump truck.
VAF #897 Warren Moretti
2021 =VAF= Dues PAID
Old 12-04-2021, 12:17 AM
Dan 57's Avatar
Dan 57 Dan 57 is offline
Placing a heavy FP prop, gadgets, or fat pilot/pax on an RV 3, 4, 6, 7, or 8, makes your RV handle like a dump truck.
And cruising at 2600 RPM iso 2300 or 2000 gets you tired quickly, not even touching the single speed efficiency here…
- ain't the Destination, but the Journey -
www.aerofun.ch
Old 12-04-2021, 02:11 AM
rv8ch's Avatar
rv8ch rv8ch is offline
I have never driven a dump truck, but now I want to give it a go, if it's as fun as my RV-8!
Mickey Coggins
http://www.rv8.ch/help-people-in-ukraine/
Old 12-04-2021, 04:35 AM
plehrke's Avatar
plehrke plehrke is offline
24 posts on this thread and no one has mentioned nose gear vs taildragger and its relation to prop selection.
Choices and opinions are what makes Experimental Aircraft the best Aviation.
Philip
RV-6A - flying 1000+ hours
Paid dues yearly since 2007
There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. —MARK TWAIN
Old 12-04-2021, 07:54 AM
PilotjohnS PilotjohnS is offline
Default Red October
As Sean Connery’s character said, “We all have are reasons”
John S
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done
Fiberglass 90%
Old 12-04-2021, 08:54 AM
brad walton brad walton is offline
I'm not knocking constant speed props. There are some advantages. Like better climb for the first sixty seconds of flight. CS and FP climb the same after about 120 knots. If you need CS to slow down, perhaps your energy management needs some attention. What I object to is the old saw of "stuck in one gear". CS allow you to cruise at a lower rpm. My fixed pitch Catto runs turbine smooth and quite efficiently at all rpm, not tiring at all. I recall a comment in the RVator that switching from FP to CS felt like a broken motor mount. And being 40 lbs lighter allows the full feel of the design to shine through. These planes just feel best when flown light. So if your mission is mainly cross country, you may want CS. If your mission is total performance, you can't go wrong with a well matched FP. As Van's used to say "build it light and keep it simple".
Old 12-04-2021, 03:35 PM
Carl Froehlich's Avatar
As someone who started out with a FP prop (RV-8A) and replaced it with a CS prop (Hartzell BA), I can report that putting a FP prop on that plane was the one big mistake I made on that build.
If you want a plane to fly for the $100 hamburger then it makes little difference. If you are looking for efficient cross country, the choice is obvious.
Carl
Old 12-04-2021, 04:18 PM
WA85's Avatar
WA85 WA85 is offline
I primed of all my parts with rattle can primer!!!!! and it made no difference in how fast I can do!!!!
Old 12-05-2021, 06:49 PM
David Z David Z is offline
Placing a heavy FP prop, gadgets, or fat pilot/pax on an RV 3, 4, 6, 7, or 8, makes your RV handle like a dump truck…
Quite curious how the RV 3 handles with a fat pax? I'm sure it would be fine with the weight of a nose gear, a constant speed prop, but no primer.
RV8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage assembly, it's a riveting job!
83126
Dash 8 day job is financing the RV8
Donation till September 2022
