Old 11-18-2021, 10:23 AM
moespeeds moespeeds is offline
Default Cruise speed - 360 with a Fixed Pitch Prop?
For the guys running fixed pitched props with a 360, what kind of cruise speeds and climb rates are you seeing?
Anyone running a 3 blade FP?
Asking for a friend.
Moe Colontonio
Cherry Hill, NJ
RV-8 N495T
Old 11-18-2021, 01:49 PM
bifft bifft is offline
I'm running a O-360 with a Catto 3-blade on my 8A. I bought a used "RV-4" prop, design specs from the dataplate:
Diameter: 66 inch Pitch: 76" RV-4
Engine O-360 Design PM 2800
Prop Red Line RPM max 3200
For max speed I get 165 KTAS at 8000 MSL and 2800 RPM. But since the redline on the engine is 2700, I usually run it at 145-150 in cruise. 145 KTAS at 8000 MSL comes out to 8.5 gph.
On climb I get around 1250 fpm, that is also at 8000 MSL. The ground around here is 5000, so I did my climb testing up that high. I estimate I should get about 1400 fpm down at sea level, if I ever take my plane there.
Old 11-18-2021, 01:55 PM
PhatRV PhatRV is offline
I guess the top speed can vary with the ground adjustable fixed pitch propeller too.
RV8 (N38PV): 90% completed (90% to go)
Waiting for hangar.
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Painting: 50% completed
Donation paid through 2022
Old 11-18-2021, 03:29 PM
mike newall's Avatar
mike newall mike newall is offline
"Asking for a friend....."
Hahahahahahha
Love it.
Fit a C/S prop and enjoy the full fun that an 8 can provide
I'll get my coat.....
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2021
Old 11-18-2021, 03:33 PM
Hahahahahahha
Love it.
There's always that one guy....
I'm quite happy with my Whirlwind 200RV. I really am asking for a friend.
Moe Colontonio
Cherry Hill, NJ
RV-8 N495T
Old 11-18-2021, 08:20 PM
If your fixed pitch prop is pitched for cruise (2700 RPM @ WOT), then your top cruise speed should be the same with both props - both being limited to 2700. The fixed pitch might have a slight speed advantage because of its lighter weight. Thatís what I found out when running against two O-360 powered RV8ís with carbon fiber Hartzells in my RV4 with itís carbon GA Sensenich at WOT at about 1,000í AGL. I was 1-2 knots faster. The trade off was in takeoff distance and initial climb. I could still get off the ground in less than 500í, and climb to pattern altitude by the end of our 5500í runway, but the CS RV8ís could get off a little shorter and initial climb was better. Cruise climb at about 135 KIAS was about the same at WOT, the fixed pitch being at a lhigher RPM/ lower MP. The biggest difference Iíve seen in my airplanes is that for a given percentage of max power (ie. 65%), the fixed pitch will be running at a higher RPM - with a corresponding lower MP, because you canít run WOT at 65% unless you are relatively high, and then youíll likely see something close to 2700 RPM. Thereís nothing wrong with this. Lycoming says you should be able to run this engine at 2700 to TBO without problems.
SH
RV6/2001 built 2000/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019/sold2021
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2022
Old 11-19-2021, 12:35 AM
YvesCH YvesCH is offline
My specs are:
Engine: Superior IO-360-M2S with dual PMag
Prop: Catto 3 blade, 68" diameter, 76" pitch
75% Power:
@3000ft: 2510rpm / IAS 156kts / TAS 165kts / 24.4" MP / 8.9 usg/hr
@6000ft: 2610rpm / IAS 159kts / TAS 174kts / 22.8" MP / 9.1 usg/hr
55% Power:
@3000ft: 2220rpm / IAS 136kts / TAS 144kts / 20.1" MP / 6.8 usg/hr
@6000ft: 2220rpm / IAS 134kts / TAS 152kts / 19.1" MP / 7.1 usg/hr
Those are measured values of my flight testing... But not yet lean of peak.
Then also the climb performance as well as takeoff and landing performance. But they were done when I did not yet had to much experience (below 30 T/O and LDGs in total) thus they may could be improved.
Regards,
Yves Heller
ID:	18450  Click image for larger version
ID:	18451  Click image for larger version
Yves - Basel, Switzerland
RV-8 #83458 HB-YUA
Donation 2020 done
Old 11-19-2021, 02:00 AM
Default Frugal Cruise
Originally Posted by moespeeds View Post
fixed pitched props with a 360 - cruise speeds and climb rates
I flew and RV-8 with an O360 and a Catto 2-blade pitched for cruise.
The initial climb was 2000fpm at sea level and it tapered to 1500 rpm by 4000ft.
It would "frugal cruise" at 160kts. Above 6500ft the fuel flow was 8.5gph or less as altitude increased.
Old 11-19-2021, 06:15 AM
wilddog wilddog is offline
Rv-8, Titan IO-370, WW GA prop, 1032#, WOT @ 7750’ measured with auto-pilot and 4way GPS runs avg. 179kts@2780rpm, 22.8”MP. Goes faster down low. Have not measured climb but it is sufficient. Engine is low CR on Mogas, Slick and SDS, AFP FI on cold air slump, 4pipe exhaust.
Old 11-19-2021, 07:36 AM
WA85's Avatar
WA85 WA85 is offline
Default RV-8 with IO-320 FP
I know the thread was asking about 360 cruise speeds with a FP prop....but just a data point.
My RV-8 with an IO-320, W-W ground adjustable prop cruises at 155 kts true airspeed at 65% power (as computed by the Dynon SV) at 7.5 GPH rich or peak. 75% at 8.5 GPH is 163 kts true airspeed, WFO at 7500" DA is 173 kts true airspeed at 13.5 GPH. Reducing drag and weight are the keys to speed and climb. I have my W-W pitched for best climb (1200 fpm at 115 kts Indicated airspeed through 5000 DA), but this leads to slight prop overspeed at WFO. I have pitched the prop for best speed and made it to 177 kts true airspeed with a significant drop in climb performance. Yes, a C/S prop would be nice, but my engine isn't plumbed for a prop governor, so sometimes I just happy to have an RV-8 and the ability to go fly...
