kens_cockpit
I originally planned on an IO 360 with a constant speed prop. I have the IO360 cowl
Fora number of reasons I have decided to change course as I have acquired an 0320 and I will put a fixed pitch or ground adjustable prop on it, at least initially.
I need to add the scoop to the bottom cowl for the vertical induction. It looks like I can buy that from Vans and attach it.
Are there other differences I need to look out for? For example will I need to modify the baffling etc
Are the external dimensions of the engines essentially the same?
What size prop spacer will I need?
Thanks for your thoughts.
