Im wiring a ground start plug set up. I have a two post solenoid that requires a diode between the two post. I cannot find anything that discribes what diode is used. I have an extra "Van's start solenoid diode" left over, can I use this for the ground power. If not, is there a part number for the one I need. On the diode, how do you know the direction current flows. Thanks....
