Old 04-25-2022, 06:02 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by TShort View Post
Very cool.
I would be interested in some of the how you did it details…
Start by separating every part from every part. The big chunks went back on the trailer and were hauled to a sandblasting shop. Smaller stuff got a pass through my bead blast cabinet after protecting all sensitive surfaces, like bushings and shafts.
Next is repairing or replacing all broken or worn out parts. After ~80 years of airport apes, there will be some. Can't buy most of it, so it's all fabricated. The adjustment end plate in the brake photos is a good example. The pivot point had a large, badly worn slot. So, cut out that portion, weld in a new section, bore the correct hole.
Primer and paint is Richards single part industrial polyurethane. Brush on all the primer to really saturate the sandblasted surface. Sprayed most of the color.
If there's a catch, it's the weight of the parts. I used a Kubota with a front end loader to lift and position as needed.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-25-2022, 07:55 AM
spark68 spark68 is offline
Default shear blade
Originally Posted by Nick Leonard View Post
I have a four foot shear that needs to have the blade sharpened. Any ideas on how or who does this sort of thing?
Shear blades usually have 4 sharp edges. Flip the blade to expose an unused edge, if not already used. Need to re-set the blade to blade clearance by shimming. Too little clearance will wear the blade edge quickly and increase the force required. 10% of the thickness of material to be sheared is about right.
Mark Curley
RV-6 status: finish kit
dues paid 2022
Old 04-25-2022, 08:08 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Before and after. Whole lot of heavy lifting between those photos...
Beautiful work Dan. We took delivery of a very similar brake - brand new - in I believe '75 or '76 and it didn't look as nice as this. My brother and I spent many hours using that thing, "racing" another team on a similar one. We were paid the princely sum of $2/hour each. It was heaven!
Mickey Coggins
http://www.rv8.ch/help-people-in-ukraine/
Old 05-14-2022, 11:17 PM
DanH's Avatar
Third and final of the trio, a 42" Pexto slip roll.
Love that ancient extra chunky grease
Name:	Slip Rolls.jpg
ID:	25820  Click image for larger version
Name:	Slip Rolls 2.jpg
ID:	25821  Click image for larger version
Name:	Slip Rolls 3.jpg
ID:	25822  Click image for larger version
Name:	Grease Chunks.jpg
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-15-2022, 08:01 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Nice looking restoration Dan. Cool!
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 457.6 hrs. on the Hobbs,
RV10 95% built- Sold 2016
https://www.youtube.com/channel/UCiy...g2GvQfelECCGoQ
