Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
11-29-2022, 05:03 PM
TruTrak Autopilot issue
I have the TruTrak autopilot shown in the attachment and have a problem. It wanders 10 degrees either direction. It's installed in an experimental Maule, but a friend told me that this old unit used to be quite popular in the RV community and that maybe someone here would have an idea.
You can see the problem clearly in a video I made here: https://youtu.be/b-ds_jEp5LM?t=83
Any help would be greatly appreciated. Maybe it's just a bad unit, but thought it was worth asking.
11-29-2022, 06:20 PM
Senior Curmudgeon
Welcome to VAF
Rich, welcome aboard the good ship VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
11-29-2022, 08:22 PM
Thanks Mike!
11-30-2022, 06:16 AM
Download the instructions, go back to square 1, re align everything from scratch.
When you turn it on, always allow it to erect itself when you are absolutely still on the ground.
This was sage advice from Andrew at whoever Trutrak are now and worked for us.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2022
11-30-2022, 08:57 AM
I didn't do the installation on this, so probably good advise in any case to verify that everything was done correctly. I'll give it a try. Thanks for the tips.
11-30-2022, 09:29 AM
VAF Moderator / Line Boy
I’ll second the comment to not move the airplane until you see it finish its boot-up cycle - you’ll know that when it says “autopilot Off” (at least on our TT’s - not absolutely sure what you’ll see, but it takes about 30 seconds). If you power it up while you’re moving, it’ll never settle down….
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
11-30-2022, 03:24 PM
The advice given here is great!
1. Check control/autopilot system for lost motion.
2. Don’t move until boot is complete.
3. Make sure you have a good GPS signal to the AP for best performance.
4. Look at AP settings (the advice to start again from base settings and adjust one thing at a time is perfect).
5. As always, shoot me an email…while I may not be the fastest to respond, I do try to help everyone that has a TruTrak make it fly as it should! :-)
Andrew Barker
Andrew.Barker(at)Honeywell.com
Honeywell
TruTrak
RV-4 214NY "Carrie Ann"
RV-10 989TS - undergoing complete overhaul!!!
Rans S21 - 6219B
EAA - 309420
11-30-2022, 05:11 PM
check the shear screw.
RV-6, bought from builder.
O-320, slider, carb, mags, FP
11-30-2022, 08:43 PM
1: I don't know what that means.
2: Wilco
3: No GPS. Heading only on this one.
4: Wilco
5: Thanks!
11-30-2022, 08:53 PM
2: Wilco
4: Wilco
5: Thanks!
1. Check for any free play between autopilot servo and ailerons/elevator. This includes prior suggestion that maybe the shear screw is sheared.
3. Andrew: my recollection, maybe faulty, was that ‘heading’ was actually gps track?? If so I don’t know what happens with no gps.
OP: mid-continent instruments now provides service, although this unit is pretty old, I’m not sure.
Thread Tools |
Display Modes |
