Old 05-20-2022, 07:30 PM
NinerBikes NinerBikes is offline
Well, Jim, running full synthetic Mobil 1 4T motor oil and Mogas that's free of lead and up to 250F oil temps seems to be OK, if only done on occasion? I'd keep an eye on oil temperature, myself.
I ran Mobil 1 4T exclusively with Mogas, and almost always tried to keep my oil temps at 230F or less, not letting it get into the yellow range. Summer time and 1800 to 2000 feet AGL is all I would get, before backing out of throttle to 5000 rpm and level flight to cool down my oil temps. Those were personal limits I set, myself.
Biggest problem was that summer time around here almost always had temperature inversions that caused 4000- 5500 ft of altitude climbing necessary to get to the cooler atmospheric air above. Takes a long trip to make it worth the climb.
VAF dues paid 2022
RV-12, KWHP based
"Time to Spare, go by Air."
Old 05-26-2022, 11:34 AM
seagull seagull is offline
Has anyone found a larger oil cooler that fits the -12?
I know other planes with the 912 have larger coolers.
I would think that would solve the heating issue in hot climates.
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Old 05-27-2022, 06:57 AM
bobg56 bobg56 is offline
If I was getting up to 250F I'd verify the oil temp using a Laser thermometer or dip probe into oil tank or maybe change out temp sensor
Old 06-18-2022, 08:06 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
As a follow-up to my original post #1… I modified the lower cowling to move the oil cooler 1” forward. Worked a charm… Now in cruise flight, at 75 OAT, I see 207F oil temp. I should have no problem staying in green arc with exception of long climb on really hot day.
Click image for larger version
ID:	27175  Click image for larger version
ID:	27176  Click image for larger version
ID:	27177  Click image for larger version
Name:	Screen Shot 2022-06-18 at 10.02.30 AM.jpg
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 780
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 06-18-2022, 08:52 AM
Too bad the mold for the original lower cowling didn't take this into account. Fiberglass is really itchy work. Plus if your lower cowling is already painted, more rework.
VAF dues paid 2022
RV-12, KWHP based
Old 06-18-2022, 11:32 AM
[quote=Piper J3;1614662]As a follow-up to my original post #1… I modified the lower cowling to move the oil cooler 1” forward. Worked a charm… Now in cruise flight, at 75 OAT, I see 207F oil temp. I should have no problem staying in green arc with exception of long climb on really hot day.
-[/QUOTE
That is an amazing change from your previous numbers of 231f with OAT of 68.
I also have a 1" gap between my muffler and cooler. At 75f OAT, level flight, 5400 RPM, 118 TAS, gross weight, I have 235f on the oil temp.
I can lower the oil temp to 220f if I lower the RPM to 4800 but that drops the TAS to 105 KTS.
-- Walt --
Old 06-18-2022, 01:27 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Jim,
Good report and nice neat work on the cowl!
Tony
E-LSA RV-12 ULS
Old 06-18-2022, 04:28 PM
Piper J3's Avatar
Originally Posted by seagull View Post
I also have a 1" gap between my muffler and cooler. At 75f OAT, level flight, 5400 RPM, 118 TAS, gross weight, I have 235f on the oil temp. I can lower the oil temp to 220f if I lower the RPM to 4800 but that drops the TAS to 105 KTS.
There is a “Heat Dome” forecast for Tues/Weds with temps in the mid-90’s. I’ll fly then and report-out with data….
Old 06-19-2022, 09:31 AM
Do you have to replace the oil hoses to the oil cooler to allow for additional distance?
VAF dues paid 2022
RV-12, KWHP based
Old 06-19-2022, 11:01 AM
Piper J3's Avatar
No, hoses have enough slack to accommodate without stretching....
