Keep VAF
Going
11-16-2021, 08:24 PM
Are All Pitot Tubes Equal?
We are definitely looking at heated, AOA/Pitot combination. They are available from several manufacturers. Do they interface the same way to the various avionics manfuacturers? We're not even close to looking at avionics.....
TIA!
Mike
DUES REMINDER: JAN 2023
RV-10
Tailcone: 90%
Wings: In Progress!
Fuse: Ordered
Finish: Ordered
FWF: Ordered
Engine: Ordered
Prop: Ordered
11-17-2021, 08:23 AM
Has anybody tried putting a rivet like a static port in the wing at a 45 degree angle for the AOA?
9A flying
11-17-2021, 08:44 AM
One of the better standalone systems uses about a ⅛ inch hole drilled on the top and bottom of the wing.
RV-6 sold
F-1 Rocket
11-17-2021, 09:21 AM
TIA!
Mike
I am using the Dynon Skyview so I installed the Dynon AOA/Pitot tube since the AOA inlet bevel angle at the tip matches to the Dynon AOA algorithm. I think the same logic applies if you choose Garmin avionics, then you would probably get the Garmin brand pitot.
RV8 standard build: 90% completed (90% to go)
Waiting to install wings to fuselage.
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Donation paid through 2022
11-17-2021, 04:17 PM
I have the Dynon pitot but since the AOA requires an in-flight calibration, I suspect it would work with any similar pitot However, I strongly recommend a pitot with a temperature regulated heater. Compared to an unregulated heater, you'll (1) use less power under most situations, and (2)won't burn the s... out of your hand if you touch it on the ground to "see if it's working".
11-17-2021, 05:26 PM
This was discussed previously here, and it apparently works. I’m going to try it on my RV6 I’m building. My fuel tanks are off, so I can get to the inside of my wingtip and get to the inside of the pop rivet, AKA, a Vans static port. The link above shows an approximate angle for the rivet. Not critical, since you program it in your EFIS.
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019/sold2021
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2022
11-17-2021, 06:44 PM
Why would you do that, when you can just add another tube with a 45* end to your existing pitot tube??
VAF #897 Warren Moretti
2021 =VAF= Dues PAID
11-18-2021, 06:38 AM
Drag and appearance.
Finn
N214FL RV-4 Mazda 13B Renesis First flight 20 Feb 2021
N46AZ RV-3B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
11-18-2021, 07:43 AM
Yes, but not as simple as stated and definitely not 45*. Works very well on my 10 and this is now a vans option for the 12.
I put mine in the outer most bay of the wing so that I could access the backside on an assembled wing. Use 1/8" tubing and insert it into the 1/4" tubing and seal.
Larry
Thread Tools |
Display Modes |
