Old 09-15-2021, 10:32 PM
mc607 mc607 is offline
Default GMU 22/ GTP 59
Iím planning to put the GMU 22 in the left wing oem inboard location. There is a prepunched hole in the left inboard wing skin, next to the inspection cover, that is for the OAT probe. Has anyone had the GTP 59 probe cause EMI, being that close to the GMU 22?
Old 09-16-2021, 06:00 AM
Nova RV Nova RV is offline
None, works great.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 09-16-2021, 11:17 AM
Thanks Chris. Do you have the G3X and if so did you mount ADAHRS to back of GDU? Iíve spoken with Stein Air and Garmin. Stein says should be ok and Garmin said the issues theyíve seen are related to panel flexing. I plan on using thicker material and stiffeners on my panel to prevent that, even if I donít mount ADAHRS to back of GDU. Nothing good can come from a panel that moves.
Old 09-16-2021, 11:22 AM
I have the G3X and the ADAHRS is on the back of the PFD screen, never an issue or error or problem. I know the East Coast demo plane for Vans has it mounted this way. My guess is that some other planes have panels that flex and can cause problems but no complaints that I have heard on a 14.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
Old 09-16-2021, 11:54 AM
Thanks for the quick reply Chris. Glad to hear itís been trouble free. Getting close to finishing left wing. Wouldnít mind your feed back on my pitot/AOA mount. Mount is in approx. OEM location. Iíve twisted the power lines and plan on running them as far aft as possible in the aft most rib setup hole. I enlarged them slightly as per Vanís.
I plan on going through the lightening hole at the I/B flap bracket and then back to the set up holes.
Old 09-16-2021, 11:59 AM
Havenít quite figured out how to put more than one picture in a post...or rotate em
Old 09-24-2021, 09:21 PM
lluciani's Avatar
lluciani lluciani is offline
I have the GMU 22 and GTP 59 at these locations and haven't had any problems. I also have the ADHRS mounted to the back of my pilot side G3X and no problems there either.
RV8 - built and sold after >400 hrs
RV14A - built and flying
Old 09-25-2021, 06:48 AM
Awesome, thanks
