  #11
Old 09-26-2020, 07:38 AM
Originally Posted by Janekom View Post
Thank you for all comments.
Oh by the Vlad I think you might have some of my Intersection Fairings on your RV like hundreds of others.
We were just talking about those robust little things. You shipped them direct to me from SA. The amount of beating the fairings took is unimaginable. Still attached great job Jan thanks!
Old 09-26-2020, 09:40 AM
Janekom's Avatar
Janekom Janekom is offline
Great stuff Vlad 🤗
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2021 WITH A SMILE
Old 10-03-2020, 11:20 PM
Janekom's Avatar
What I did not mention is that there is a wire you can connect to sync the two strobes. Then there is also a built in function to strobe the landing lights as well as a wig wag mode for the landing lights.
Below is the rear of the module where you can see the three switch mode power supplies and weatherproof connectors. Note the metal cans in order to contain RF noise.
Jan Hanekom
South Africa
Old 08-12-2021, 08:13 AM
Janekom's Avatar
Default RV10 update
Just an update - I have recently acquired an RV10 and therefore had the time to see how an install these light modules into the RV10 wingtip. It was actually quite easy by just adding an adaptor plate that moves the bases slightly inboard. It does not affect anything else like light angles. Really happy with it. Now to update the install documentation.
The first picture is of the one wingtip with the old nav/strobe removed. The second picture is the end result. The carbon fiber is vinyl to cover the old marks and holes.
ID:	14604  Click image for larger version
Jan Hanekom
South Africa
Old 08-15-2021, 01:28 PM
Janekom's Avatar
Default Fitted them yesterday
Fitted them yesterday and they working very well.
Jan Hanekom
South Africa
Old 08-15-2021, 05:02 PM
scsmith scsmith is offline
Very cool.
I also have a taxi light in each tip, aimed differently than the landing light because it is tailwheel. Any solution for that?
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 08-17-2021, 01:49 AM
Janekom's Avatar
Hi Steve,
The lights are easily adjustable by loosening the screw and moving it up or down. If one only use these in the tips I would think of having on at 0 degrees and one at about 10 degrees down, with reference to the wing chord line.
Also keep in mind that the lenses are 10 degrees which on it's own is a nice spread.
Below is a picture where you can clearly see the adjustment screw and slot.
Jan Hanekom
South Africa
Old 10-02-2021, 12:42 AM
Janekom's Avatar
Default They are now available in the USA
I am very exited to announce that these RV wingtip nav/strobe/landing light modules are now available from Flyboy Accessories. They have stock.
https://www.flyboyaccessories.com/product-p/73401.htm
Jan Hanekom
South Africa
Old 10-04-2021, 10:54 AM
MGR1977 MGR1977 is offline
Welgedaan oom Jan!! Lyk na nog een van oom se goeie produkte! Translation for the Yanks on the forum - "Well done uncle Jan! Looks like another one of your great products!"
Old 10-05-2021, 02:15 AM
Janekom's Avatar
Default Thank you
Ngiyabonga Nthati - Baie dankie
Jan Hanekom
South Africa
