Old 08-08-2021, 10:28 AM
RicoB's Avatar
RicoB RicoB is offline
Default Tip up canopy front seal
Has anyone found a good seal for the front area of the tip up?
I tried a teardrop seal that I found on Amazon but it’s a lil too thick. If I could find a real thin wall teardrop seal would work great I think.
Any other suggestions ?
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
https://www.imdb.com/name/nm3018529
Old 08-08-2021, 11:23 AM
Paul 5r4 Paul 5r4 is offline
I'm hoping you get some good suggestion here. I have a tip up and found out the hard way to stay away from rain!
Paul Gray
Foley, Alabama
N729PG..... 500+ hrs
RV 7A, Lycoming 0 320 D1A, Sensenich FP propeller
pilotforfun2001@yahoo.com
VAF supporter $$$
Old 08-08-2021, 12:00 PM
mr.sun mr.sun is offline
Yep, Me too. I'd like to find a better front canopy seal
Greg RV-7 flyer
Donated Again
Old 08-08-2021, 01:32 PM
lr172 lr172 is offline
I used a D shaped seal from Mcmaster and it works well. Get a few drops inside during rain while at cruise speeds. Key is to maintain a consistent clearance between the flange that holds the seal and the skin. Each different seal has it's own optimum compressed height (often 30-40%). Be sure to get one that matches your clearance.
larry
Old 08-08-2021, 01:33 PM
Finley Atherton Finley Atherton is offline
A search should bring up suggestions. Search “tip up canopy seal” on this website and “vansairforce tip up canopy seal” on google.
My suggestions are HERE posts 4, 7 and 9.
Fin 9A
Old 08-09-2021, 01:52 AM
newt's Avatar
newt newt is online now
Amazon sells 6" wide self adhesive vinyl paint protection film tape from 3M.
https://www.amazon.com.au/Clear-Pain.../dp/B01LWPKZCF
Cut two lengths, long enough to cover the flat bit of the gap between the canopy leading edge and the cowl.
On one of them, trim off an inch of width, so you have a strip that's 6" wide and another strip that's 5" wide.
Peel off the backing and stick the sticky sides together, so you have a 6" wide strip with 0.5" of stickiness along each long edge, and a 5" bit in the middle that's not sticky at all. (or trim the whole lot narrower if you want, it's up to you and your personal aesthetic)
Apply it over the gap with the canopy closed, so it sits flat and flush with the fuselage. Leave it for long enough for the glue to go off properly; Then you should be able to open and close your canopy without interference, and when it's closed almost all of the gap will be covered over with waterproof vinyl.
It gets a bit yellow with age, and shows up any dirt that gets underneath it. But it's cheap, and you can replace it whenever you get sick of looking at it.
You can see it in the attached photo. It got replaced a couple of weeks after it was taken 'cos I got sick of looking at it :-)
In concert with a bead of synthetic rubber doorway draft-seal from Home Depot along the entire length of the hinge line, I've found that this almost completely prevents ingress of water, even in moderate rain.
(Not my idea, it came from Lyndon Tretheway at Custom Aircraft Centre in Goolwa, South Australia)
- mark
[ Paid up on 16 Jul 2021 ]
RV-6 VH-SOL
Old 08-09-2021, 01:56 AM
newt's Avatar
You can see it with the canopy open during an oil change here, which should give you a bit of an idea about how it's attached.
- mark
RV-6 VH-SOL
