Old 06-18-2021, 08:59 PM
dmat dmat is offline
Default G3X layout in Tip-Up 6?
Hi,
1) does anyone have a pictures of their G3x touch layout in a tip-up?
I am going with a 10in screen,650,AP head, gtr200 and remote adsb unit.
2) how did you modify the bracket which hold the panel to accommodate the 10in screen?
3) where did you put all the units behind the panel?
D
- RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
- RV6: N130PJ
Donations Paid- Thank you VAF!
Old 06-19-2021, 10:19 AM
bjdecker's Avatar
bjdecker bjdecker is offline
Default my panel
I have 2 G3X touch (GDU 460 & GDU 465), GMA 245, GTN 650xi, GTR 200, GTX 345, GMC 307.
I made the instrument panel 1" lower (taller?) to accommodate my switch/buttonology & breakers.
I relocated the ribs to each side of the radio stack.
The GAD 27, GAD 29, GEA 24 are mounted on sub-panel behind the MFD. The GSU 25 is mounted on the back of the PFD.
-- Regrets --
Should have used GDL 51R for SXM instead of GDU 465 (XM weather data is not shareable between GDU 465 and 460)
Should have used GMC 507 instead of GMC 307 (easier to wire)
ID:	12815  Click image for larger version
ID:	12816  Click image for larger version
ID:	12817  Click image for larger version
Brian Decker
RV-7 (Flying)
Old 06-19-2021, 10:46 AM
PilotjohnS PilotjohnS is offline
Default Say what?
Say what? I did the gdu460 and GDL 51R. I was cursing myself for not using a gdu465 instead. Wiring up the gdl 51r and finding a spot for it is a pain. It has to be close to horizontal, gets lots of wires, etc.
Now you are saying I did the right thing?
I’m a poet but dont know it.
Thanks for the feedback, I guess my cursing was due to ignorance; I feel better now.
John S
Dues paid 2021, worth every penny
RV9A- Status:
95% done, 15% left to go
Electrical/Panel 95% done
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
Old 06-19-2021, 02:48 PM
bjdecker's Avatar
Iím a poet but dont know it.
You did it correctly IHMO -- the GDU 465 doesn't "share" the Sirius XM data, or the Sirius Radio tuning functionality with the GDU 460....
Brian Decker
RV-7 (Flying)
Old 06-19-2021, 03:13 PM
Hey Brian, thanks for the pics. That makes total sense to relocate the brackets. I will probably only relocate one as I plan on only one screen.
But this is very helpful!
D
- RV6: N130PJ
Old 06-19-2021, 04:08 PM
Default Just me
D
You might consider making provisions that alllow accommodating two screens now. It will be very difficult to relocate the other bracket in the future.
John S
RV9A- Status:
Old 06-19-2021, 05:33 PM
KiloFoxtrot's Avatar
KiloFoxtrot KiloFoxtrot is offline
Hi,
D
I took a different approach than what I have seen out there. I have a 7A T/U and using the standard Vans panel with all the following items on the panel.
Dual 10" G3X. G5, GTN650xi, GMA245, GTR200, GMC507.
I cut a hole for the center stack avionics in the sub panel and surrounded it with angle. Above and below the hole cutout I have angle running horizontal. The top piece you can see in the picture and the bottom piece I mounted on the forward side of the subpanel. You can see the rivets for the bottom angle piece. The architecture of the center stack frame is extremely strong an possibly a bit over the top in construction. I figured that 20lbs of avionics at 6G can get get a little heavy for that thin subpanel not to mention the large hole cutouts in the panel for 2 screens and a full center stack. I even strengthened the panel where the top outside corners of the screens get close to the panel edge.
This was just my approach using the standard panel Van's supplied. Others may share something you prefer better.
ID:	12822  Click image for larger version
ID:	12823  Click image for larger version
ID:	12824  Click image for larger version
ID:	12825  Click image for larger version
RV7A tip up
Superior IO-360-M1S Aerosport build school=Excellent. See post: Engine build school pictures IO-360
Tail / Fuse / Wings are complete + painted. I used Sherwin Williams JetGlo solids and AcryGlo metalics.
Leather seats by Flightline Interiors.
Still to do: Firewall forward, cowling fit and paint, G3X avionics.
FLY
Old 06-19-2021, 05:37 PM
-- Regrets --
Brian,
Very Nice Panel work.
Can I ask you what switches you have and where did you get them?
Ken
RV7A tip up
FLY
Old 06-19-2021, 07:29 PM
bjdecker's Avatar
Originally Posted by KiloFoxtrot View Post
Brian,
Ken
Honeywell AML24FB series, with AML54-F operators - engraving done by Aircraft Engravers.
Brian Decker
RV-7 (Flying)
Old 06-20-2021, 11:07 AM
Thanks Brian!
RV7A tip up
FLY
