Old 06-17-2021, 01:10 PM
motodave motodave is offline
Simple fix, I just flipped the standard Van's bracket over to other side (with a little bending to clear the pan) and put the bolt and spacers on on the throttle arm on the other side also:
Untitled by Dave Hock, on Flickr
Tons of clearance now to the hot exhaust pipes!
Dave
RV7 Slider N732DH reserved
I(O)360-M1B Thunderbolt
Empennage 100% Complete
Slow build Fuselage 95% done
Wiring 40% done
Was QB wings now will be slow build...
Littleton, CO
Photo log: https://flic.kr/ps/9jjZz
Old 06-19-2021, 08:01 AM
John Tierney John Tierney is offline
Here's how I shielded my throttle cable from exhaust. Works OK through 90-hours. I have a Superior cold air sump. so I had to fabricate an additional plate to use the Superior boss with the Van's bracket.
If I remember correctly, I did have to warp or flare out the sides of the shields a little bit due to exhaust pipe bends.
ID:	12808  Click image for larger version
ID:	12809  Click image for larger version
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 06-21-2021, 05:43 AM
Iluke Iluke is offline
Default Throttle bracket
Here are some pictures of my homemade throttle bracket. Like other's the Vans supplied bracket positioned the cable too low. I made this out of 4130 sheet. It positions the cable higher, closer to the sump. As an added benefit, it gave the cable a slightly better angle relative to the linkage.
Haven't flown yet, but I have run the engine on the ground and no problems so far.
Mine is a factory Lycoming IO-360-M1B bought through Vans.
Ivan Luke
Hope Valley, RI
RV-7 SB
Flying as of 9/13/21 (9 1/2 years!)
2021 dues paid
