Old 06-16-2021, 05:23 PM
Sully73 Sully73 is offline
Default RV-4 Paint
Paint decisions,
My plane is not intended to be a show plane. Just something to fly and look reasonably good. I am using a local auto paint shop to shoot the paint.
I plan to use the "Prekote" treatment instead of alodine, prime, paint, then use Vinyl decals for numbers and accents.
The local paint store recommended the PPG CPC single stage urethane paint. Does anyone have experience with this product?
Or they said I could spend 4X and use the PPG Concept?
Any advice on any part of my plan?
Old 06-16-2021, 05:40 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Just for fun, do a web search on painting airplanes with latex. Pretty amazing...
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
Vaccines kept me out of the hospital but COVID still cost me a month of living, all told...
Old 06-16-2021, 06:14 PM
Originally Posted by Sully73 View Post
Paint decisions,
I think your low cost plan is great. Keep it in a hangar and the paint will be happy for decades.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 06-16-2021, 09:16 PM
Allan Stern Allan Stern is offline
Default Painting
I bought PPG ESSS Single stage polyurethane paint for my RV 14. My painter really liked using it and it came out great. Used factory pack GM 50 Olympic white (chevy truck white) cost about $108.00 a gallon plus activator and hardener. Beats a gallon of Jet Glo aviation paint.
Old 06-16-2021, 09:56 PM
RussellT RussellT is offline
I say go for it, I used a single stage Urethane paint (Nason) and am happy enough with the end result. It's not show winning quality and probably looks like a first time painters job, but also being a first time builder it fits with my project. And it cost me less than $1000...
Having zero prior experience with painting meant I just went with the paint shop recommendations.
Prep was a thorough go over with scotchbrite and detergent, rinse and dry, wipe down with wax and grease remover, light coat of etch primer, light rub down with scotchbrite to remove any dust or bugs etc then more wipe down with wax & grease remover then the top coat. I did paint components individually before assembly.
Time will tell how it stands up but it seems to be a robust and forgiving paint to use.
Russell
Name:	Finn RV 3B (1).jpg
ID:	12719  Click image for larger version
Name:	Finn RV 3B (2).jpg
RV 3B. Very slow build. Now onto final assembly...
Old 06-16-2021, 10:14 PM
wcalvert's Avatar
wcalvert wcalvert is offline
Thumbs up
2nd for Nason Ful-Thane 2K Urethane
Easy to shoot and has nice flow out and gloss.
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
First Flight 7/17/2021!!
- Been there, Donated 2021
Old 06-16-2021, 10:43 PM
Scott Chastain's Avatar
Scott Chastain Scott Chastain is offline
Default Excellent Paint Product
<snip>
Just today, I saw the final results of a C-182 painted with that very same paint. It was a 3-tone color scheme using retro Ford colors from the 1950s. This was the pilot/restorer's first experience painting an airplane, and it came out beautifully----no orange peel, excellent gloss and holdout with only 2 topcoats. He turned his hangar into a paint booth and was also able to shoot the entire aircraft with minimal nib issues.
I think you're going to be very happy with PPG. I used the Concept two-stage system, but like you say, it is much more pricey, and usually heavier than a single-stage topcoat.
Scott Chastain
RV-8 N898W Descending Dove
Old 06-17-2021, 04:18 PM
Bandera Bandera is offline
PPG makes very nice paint. Their single stage urethane is my go to for odd color matches.
Old 06-21-2021, 05:16 AM
fixnflyguy fixnflyguy is offline
Default PPG Desothane
PPG Desothane is their premier aircraft coating. Its single stage and very tough. I painted my RV-4 with Desothane white 12 years ago, and don't even have a scratch. We use it for commercial aircraft at my day job. Easy to shoot, I painted mine myself and used the PPG DP series primer after a scotchbrite and soapy water scrub down. I also applied a cheescloth application of Alodine and rinse prior to the primer.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 06-21-2021, 12:55 PM
jlisler jlisler is offline
Default RV4 Paint
Use the best paint you can afford. I used Nason and it has held up reasonably well for the last 14 years. With that said, Nason paint will stain. Oil on belly will turn Nason white paint a dingy, brownish tinted white. Fuel will stain the paint if you leave it on the paint as in a leaking fuel cap. I have personal experience with the paint staining. My airplane looks great but I wish I had used a better paint.
Jerry Isler
Donalsonville, GA
RV4 N455J
1949 C140A N9641A
