Old 02-22-2019, 10:51 AM
gcman6 gcman6 is online now
Default RV-7 #74805 Gcman6
After reviewing the plans and build manual for a couple months, I jumped right into the empennage kit. I spent a few hours inventorying the kit and everything was present and in great condition. I then started on the rear and front spars.
There are a few tricky spots on the front spar but I was able to get everything cut, bent, and drilled correctly using some tips from other builders. I prepped the ribs and cleco?d the substructure and skins together to see how it all fits. I then got the HS-00005 and HS-00006 ribs lined up, drilled, and cleco?d together and proceeded to match drill all holes in the skins.
Next up is to take everything apart, deburr the edges and all holes, dimple, prime, and get ready to start riveting it all together.
[IMG] [/IMG]
Old 02-24-2019, 09:23 PM
Robin8er Robin8er is offline
Looks awesome. It goes together quick. Build on!
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 02-25-2019, 08:54 AM
Raymo's Avatar
Raymo Raymo is offline
Welcome to VAF and keep up the great work. One day you'll have a fantastic plane!
Ray
Old 02-25-2019, 10:57 AM
Girraf Girraf is offline
Congrats! I found the HS to be the most complex sub assembly mainly because of all the things happening in the center area with the doubler plates and having to drill some of your own holes. I spent many hours thinking and interpreting before cutting/drilling.
Looking good so far!
Vintage Cherokee 160
RV-7:
Empennage complete
SB Wings to QB stage
Fuselage in progress
Finish kit/Engine/Prop Ordered
Old 06-03-2021, 09:28 AM
Default Wings Almost Done
I haven't updated this since my first post so why not now?! The tanks and top skins are installed on both wings and they are in the rolling cradle I built. Ailerons and Flaps are done. Just need to make the pushrods and install everything. I've got plenty of time until my Fuselage kit arrives as I'm not supposed to get it until early Fall. I think I'll probably leave the bottom skins off until later as I haven't decided on Avionics. I also need to insulate and get my garage all set up for moving the shop there as I am running out of room in my basement. It's been nice to build down there though as it's cool in the summer and heated in the winter. I'll just have to sweat it out in the garage during the summers for the rest of the build.
ID:	12182  Click image for larger version
ID:	12183  Click image for larger version
______________
Garrett Clemmer
RV-7
Empennage Complete - 12/2019
Wings Started - 2/2020
Old 06-04-2021, 06:04 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default Finish
Suggest finishing wings, including lights, tips, and wing root farings.
Wires can be run later if you have conduit, or snap bushings...
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
