Old 05-17-2021, 10:09 AM
Craw's Avatar
Craw Craw is offline
Default QB Wing Flop Tube install
Good Day All,
I'm looking for pictures or a link to a blog from someone who has installed a Flop Tube on RV-7A QB wings. All the previous posts or links I have found appear to be broken.
Any insight into the install especially with pictures would be appreciated.
All the best,
Phil
RV-7A (Under Construction)
Tail Kit Started
QB Fuse&Wings Received and Under Construction
Old 05-17-2021, 10:22 AM
bhester's Avatar
bhester bhester is offline
Default Here is mine
Here is a picture of mine from 2007
Do to unrelated reasons, I am in the process of doing it again right now.
I’ll have more of the actual flop tube install soon
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2020 VAF donator - alot better than any magazine subscription
Old 05-17-2021, 10:32 AM
wirejock's Avatar
wirejock wirejock is offline
Default Flop tube
If you install it, make sure you add an antirotation bracket. There's no way to hold the fitting when you tighten the line and it can rotate and leak.
I didn't add one. I dont plan any inverted so I may remove it and switch to a standard pick up and cap the flop tube fitting for future use. I haven't joined the wings yet so it's fairly easy.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 05-17-2021, 10:41 AM
Craw's Avatar
Thanks All. Since Im working from a QB wing will I need to remove the tank or can the work be done with the sealed tank on the wing?
Tail Kit Started
Old 05-17-2021, 11:01 AM
bjdecker's Avatar
bjdecker bjdecker is offline
You'll need to open up the tank; there are some parts (anti-hang up bracket, trap door, etc.) that are different...
Have you reviewed the plans yet? DWG 16A shows this.
Brian Decker
RV-7 (Flying)
Old 05-17-2021, 11:06 AM
rv8ch's Avatar
rv8ch rv8ch is offline
You could probably do it with the tank on the wing, but it will be easier with it off. Specifically, you'll want to shake out any chips or other debris, which will be easier with just the tank. It only takes 5 mins to unbolt/unscrew the tank from the wing.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 05-17-2021, 01:14 PM
Craw's Avatar
Thanks again for the feedback. I haven't reviewed the plans yet I just wanted to get an idea of whats involved.
Phil
Tail Kit Started
Old 05-26-2021, 06:30 PM
agent4573 agent4573 is offline
http://www.rv7build.com/left-fuel-tank-part-i-4-5-hrs/
http://www.rv7build.com/left-fuel-tank-part-ii-8-0-hrs/
http://www.rv7build.com/left-fuel-ta...t-iii-8-0-hrs/
You can do the flop tube install with the tank on, but if you're relocating the resistive fuel level sensor to the back wall of the tank, the tank has to come off. I didn't look into capacitive installs, so I'm unsure if those require tank removal.
www.rv7build.com
N69ER - reserved
