Dynon HDX
jaradtke
Does anyone have or know where I can get a 10” HDX bezel or 3d printed version of the bezel to use for planning. I’m concerned about the sloped control section of the bezel obstructing the view of switches mounted below.
Any help would be appreciated.
I set my HDX recessed into the panel by making “Z” brackets and cutting the panel opening to fit the bezel periphery. It helped minimize the overhang over my switches.
STL, origami, or CAD
I made STL files if you want them. ShapeWays wants $245 for the bezel and $62 for the knob portion only. I didn't have them made.
What about using styrofoam or wood or poster-board and fabricate with ref to views in the installation manual section 4?
I came up with a blind area using SolidWorks... images below. I'm showing a 1/2" dimension for the blind area and if you made it 3/4" it would be quite conservative IMO.
Recess HDX
Steve,
I thought about recessing it the way you have, but wasn’t sure if it would alleviate the overhang as much as it appears to have. Would you happen to have a sideview you could share?
My switches are 1.375 below the bottom edge of the display. The bottom edge of the display is .875 from the face of the panel. Sitting in the seat the labels are plenty visible.
Well, my pictures are rotated. I don’t know how to fix that.
Zero4zero
How did you make or whom did you purchase those switch guards?
RV 14A 140507 flying
2020 donation made
