VAF Forums
-   GPS (https://vansairforce.net/community/forumdisplay.php?f=39)
-   -   Garmin TFR Database Error (https://vansairforce.net/community/showthread.php?t=206420)
navig8 09-09-2022 07:06 PM
Originally Posted by RV8JD (Post 1633427)
Yes, I was aware of that. Hence this comment in my post: "Not sure what this latest update adds.".
But your original question was: "What are dynamic mapping products?"
Just trying to be helpful (I need to quit doing that!)
Thanks, Carl. I appreciate the information you provided. I should have worded my question differently.
What I was really trying to ask is:
What are the dynamic mapping products that are now supported as part of this update?
I am hoping the folks at Garmin who monitor these forums might be able to provide a little more information on the update.
Eric
Ed_Wischmeyer 09-10-2022 02:24 PM
Hmm. The WiFi on the 660 died some time ago and it was way too expensive to get the unit overhauled, so now I do database updates via the USB connection on my computer. Tried to do an upgrade from 3.7 to 3.82 and the screen said Software Downloads Unavailable.
Databases upload just fine but in mass storage mode, but can't do a software upgrade in regular mode.
Longez 09-10-2022 03:33 PM
2 Attachment(s)
I just updated by my Aera 660 and Aera 760 over USB using Garmin WebUpdater. Just took a couple of minutes for each.
Attachment 30775
Attachment 30776
Steve
jliltd 09-11-2022 04:33 PM
Okay. So I got two aera 660's to download and install their updates over wifi with, one with a GDL 50 attached via hard wire cable and the other with the GDL 52 attached via hard wire cable. While the aeras in fact updated they did not send the GDL 5x update to the data links.
So I decided I will use webupdater instead so I plug a USB cable into the GDL 52 and the computer Then I run web updater. The app says it no devices found. I tried multiple times with the GDL 52 turned on. So I cannot get software version 2.19 update to the GDL 5x devices.
Longez 09-11-2022 07:35 PM
2 Attachment(s)
Jim,
As explained on the GDL 5X software page, the GDL 5X is updated by its external display (e.g. GDU 4XX, Aera 660/760), not directly from WebUpdater, and only when connected to external power.
After downloading the Aera 660/760 update on WebUpdater, make sure to click Next on this page to choose additional updates.
Attachment 30857
On the next page, you can select the GDL 5X software to be loaded into the Aera enabling it to update any connected and externally powered GDL 5X.
Attachment 30858
Steve
dmattmul 10-16-2022 10:11 PM
TFR error (Maybe)
1 Attachment(s)
While flying into Craig Field I noticed this TFR and asked Craig tower if this was active. I checked before making the trip and there was nothing. There is in another week. Foreflight has nothing. Maybe operator error but what gives. Last week similar issue for a football game that would not occur for 24 hours. Database updated this morning. What am I doing wrong?
Frustrated
RV8JD 10-16-2022 10:31 PM
Frustrated
Future TFRs are shown in Yellow, while active TFRs are in Red. I believe if you touch the TFR info block on your screen or the Airspace Info-TFR button, the details of the future TFR will show.
Here is a screenshot from ForeFlight Web taken a few minutes ago:
mburch 10-16-2022 10:36 PM
Looks like everything is working properly to me. That TFR will be active in a few days (information here). As is detailed in the pilot's guide, the color indicates whether a TFR is currently active, or scheduled for the future:
TFRs are represented as an area highlighted by red (active) or yellow (not yet active).
dmattmul 10-17-2022 08:03 AM
Operator error
Thanks, seems it was operator error. I was expecting some sort of date when I popped up the indicator box if it was in the future. The area marked around KJAX appears red but the TFR does not occur for over a week. Iíll try and poke around to see if I can get more information to be displayed on my G3X.
mburch 10-17-2022 09:10 AM
I don't see any red coloration in the image you posted - perhaps you are seeing something different you haven't shared?
