Michaelpk3
Is the 385 a direct drop in? Right now the Digiflight is connected to 430W and Garmin CDI.
The Digiflight 2 is doing some wierd stuff so I figured just change it out.
Almost. There are just a couple of minor wiring differences to accommodate the level button.
I upgraded from the Digiflight II to the Vizion in my RV-10 when they first came out. I just uninstalled the Vizion and will be listing here in the next few days if you’re looking for one.
I did this upgrade a few years back just before TT sold to Bendix.
The answer is, that depends. Do you have VS on the Digiflight II? If not you will need to replace the elevator servo.
I also had TT supply a jumper harness, this avoided having to change the wires around on the control head connector.
