H HBpilot Active Member Oct 24, 2021 #1 Hi, Anybody also having the same problem displaying ADSB info from the SKYVIEW to ForeFlight ? Dynon told me FF changed something that broke the connection. Has it been fixed ? Thanks
N804RV Well Known Member Oct 24, 2021 #2 This is the only thing I heard about. iOS 14 was released 9/20. It caused some folks problems at first. https://support.foreflight.com/hc/e...iew-or-AFS-not-showing-up-on-the-Device-page- Last edited: Oct 24, 2021
H HBpilot Active Member Oct 25, 2021 #3 N804RV said: This is the only thing I heard about. iOS 14 was released 9/20. It caused some folks problems at first. https://support.foreflight.com/hc/e...iew-or-AFS-not-showing-up-on-the-Device-page- Click to expand... Thanks ! But I have that setting turned on.
GalinHdz Well Known Member Oct 25, 2021 #4 If you are running SkyView software version 16.0.4, then you might need to install this patch. You can download the patch at: https://forum.flydynon.com/threads/software-update-16-0-4-and-lost-ads-b-472-data-processing.13922/ Look for post #8. It is SUPER easy and quick to apply.
