Visually check throttle body
Make sure it is hitting stop to stop.
Boomer
This is a classic Bendix RSA-5, but every throttle body is similar.
I usually lay a strip of paper on the pin, have someone move the cockpit throttle knob to WOT, then try to pull out the paper. If it drags, good enough.
Thanks, it must be darker in my hangar than I thought, that seems pretty obvious. What does the linkage star wheel adjust?
