walkman Well Known Member May 10, 2024 #1 Is it possible to take the linear output from a Wideband O2 sensor (0-5v) and displace as a corrected AFR (or lambda although I prefer AFR) with an unused analog input on a GRT HXr or EIS4000?
Isaac Well Known Member May 10, 2024 #2 There is a discussion on how to do this on the GRT forums. Grt Hx and efii wideband oxygen sensor display - GRT Avionics
