New Android App released for Pilots showing Aircraft Traffic (TCAS)
TrafficAssist, a new Android App that displays Airplane Traffic uncluttered to help you with Situational Awareness in avoiding a possible Collision. The App follows closely the TCAS II protocol (Except Resolution Advisories ‘RA’) using the ADSB data over Wifi using the GDL90 open protocol.
Types of ADSB-In receivers that functions with TrafficAssist:
• Stratux/FlightBox (Falken Avionics)
• Appareo Stratus 3 (in Open GDL90/Open GDL Mode)
• uAvionics PingUSB
• GRT Discovery ADSB
• Dynon SV-ADSB-472 (Using the Dynon WI-FI Adapter for SkyView)
• Levil Aviation iLevil
• other ADSB-IN devices supporting the GDL90 format using Wifi
It is highly customizable, for example you can have trend lines or not,
You can display tail numbers, you can display make and model.
The App also supports sharing the ADSB data stream for other EFB apps when used on the same tablet.
This app is free, to have an unrestricted version of the app you can purchase it for a nominal fee, search for "TrafficAssist" (One Word) in Google Play.
The free version is called “TrafficAssist Demo”
Here are some comments about the early adopters of this App:
/// Interesting app. It is only for traffic information. But it does a great job. If, like me, you find the traffic displays on the map apps, EFB's difficult to see, this app is what is needed. With different settings, selectable by the user, clean screen view, along with the ability to split screen with a map app, this allows one less tablet in your lap, and a great traffic view. Using this app just one time, will make you a believer. No more squinting to find traffic on the map app.
/// The fantastic application mimics big boys (commercial airplanes) and high-end avionics' dedicated cockpit applications. Highly configurable to your flying taste.
/// This APP does an excellent job of providing ADSB-IN traffic information while in flight. It integrates with a number of ADSB devices (I use a PING) and works seamlessly on my Samsung phone and tablet - you can even display an overlay in your EFB APP such as Foreflight or Oz Runways. The APP is simple in its presentation however the menu provides a number of customizable options so you can set it up to suit your needs. Best of all the developer is responsive to product improvements.
To learn more about the App you can peruse the TrafficAssist User Guide:
https://drive.google.com/file/d/1-7Vcgeh-3F3uLpFFVXqcWeOa8RFywHcA/view?usp=sharing
To learn more about the TCASII specification by the FAA:
https://www.faa.gov/documentlibrary/media/advisory_circular/tcas ii v7.1 intro booklet.pdf
Try it, it is a game changer for me....
As an early adopter of this APP I can highly recommend it. Its now my go-to for ADSB-IN traffic information, whether I'm on a cross country or just zooming around the local patch. Give it a go.
Can someone explain how this display or functionality is better than my Stratus ESG ADSB display on say Foreflight or IFly GPS with the sectional underlay?
At first glance it seems less clear...
Also, how does the APP differ from a true TCAS system/display (I've never used one)?
Thx!
I think the idea is that it does mimic the TCAS display, so anyone familiar with that would be instantly familiar here.
But for a GA VFR pilot I don't see the value over FltPlan Go and a Stratux... To use this i'd have to give up my moving map on my tablet.
I'm thinking as an Android App, it could run on a small retired Android phone and give a dedicated traffic display.
with some 3D print work, maybe panel mount an old phone even.
I like the display, and really like the list of aircraft types with speed and altitude - I wish my G3X Touch traffic display did that.
About the traffic alerts...a tremendous amount of validation and testing went into TCAS and ADS-B traffic alerting, I'd be very wary of relying on alerts from an app without any insight into who developed it and how it was built and tested.
ds
BASICALLY LESS CLUTTER, HAVING TRAFFIC ON A VFR TYPE MAP ALTHOUGH A GAMECHANGER IN AND OF ITSELF, HAVING IT ON A DEDICATED DISPLAY MAKES IT MUCH MORE USEFUL
A TRUE TCAS II SYSTEM IS AN ACTIVE SYSTEM BASICALLY USING THE 1090ES TRANSPONDER AND ADDITIONAL HARDWARE, TWO CONFLICTING AIRCRAFTS 'TALK' TO EACH OTHER AND WHEN CLOSE THEY WILL ISSUE A RESOLUTION ADVISORY 'RA', E.G. IT WILL TELL ONE AIRCRAFT TO CLIMB AND THE OTHER ONE TO SATY LEVEL OR DESCEND.
TRAFFICASSIST DOES NOT ISSUE A RESOLUTION ADVISORY 'RA', AS THE ADSB DATA IS READ-ONLY (PASSIVE) THE THRESHOLD FOR 'RA' IS THERE IN THE APP BUT IT IS CALLED 'CRITICAL TRAFFIC ADVISORY'. OTHERWISE IT FOLLOWS THE TCASII SPEC AS MUCH AS POSSIBLE
ds
YOU SHOULD BE WARY, BUT WHO SAYS THAT OTHER APPS DOES THAT, TRUST BUT VERIFY.
NO, YOU DON'T YOU CAN IN FACT HAVE BOTH YOUR FAVORITE EFB AND A DEDICATED TCAS DISPLAY ON THE SAME TABLET
ds
btw, if you're interested in the test effort and validation you can contact me directly;
[email protected]
As one of the testers of this app during development, I can say that "swedeflyer" listened to us and always tried to address any concerns we had.
Now, in my plane, I already have at least four (4) displays that can address traffic, so i can dedicate one to worry about that, BUT(!!!) ...
Where I see this being very applicable is where someone has a limited panel and maybe have an iPad but want to declutter the iPad app. Or, if traffic is a BIG deal for you, you can get a CHEAP Android tablet and have a dedicated traffic display.
The basic idea here is that "swedeflyer" is making available an alternative and dedicated TRAFFIC DISPLAY. And for some people, this is what they have been wanting.
Only if your tablet supports split-screen multitasking, butif it does, then yes.
With one caveat:
You must have TrafficAssist running, which will forward the data stream on the other Port. If you do not use TrafficAssist, then you cannot have 2 apps on the same device use the data stream, this because the producer of the data stream, the ADSB-IN device uses a UNICAST UPD protocol.
Advertising this as a "TCAS" system is misleading at best, it is not a TCAS system.
Maybe it's a great app, don't know, but it's not TCAS.
