Jr Hampton
Active Member
Dreaded Alt hole in cowl. Very small hole through cowl 1/8 on the outside. I'm OK with that cosmetically.
Have replaced belt with shorter and alt is at top of adjustment arm now.
want to "fix" inner hole. Thinkin cutting spare aluminum stock maybe 2"x2" square , sanding hole area down, applying Gorilla Epoxy ( as I have some already) and bonding aluminum to the cowl. 1) to fix hole , 2) to have aluminum as rub stop in case alt rubs again. Do you think good idea/work ? Or use a diff epoxy ?
