flytoday
Seems both Garmin 175 GPS and GDL 52R use Bluetooth to connect to the Aera 660 GPS.
Problem is the Aera 660 will only allow one Bluetooth connection at a time.
I’d like to simultaneously connect the 660 to the 175 to share flight plans and connect the 52R to the 660 for traffic, weather, the typical ADSB data inputs.
Is there some sort of Bluetooth hub or device that can connect two devices and merge their data, and share their data with a third device?
Will the 660 accept and properly process data from a single device that has merged the 52R and 175 data?
Or is the only option swapping Bluetooth connections while in flight?
Thanks!
Carl
Thanks!
Carl
