canopy lift cylinders
seagull
I have developed a "click" when I close my canopy from one side. The click occurs in the last 8", and is coming from the right hinge area. One thought is the canopy is twisting because the cylinders are not helping enough. I am thinking that maybe the lift assist cylinders are getting weak. Is there a spec to test their strength?
Many struts have their force printed on their label, often in Newtons. Remove the strut, compress it half way, hold it against a scale and compare the reading (convert pounds to Newtons, or vice-versa) to the spec.
We had an RV 14 on the field that had a very distinctive click. It was the canopy leading edge skirt hanging up on the fuselage upper skin. We couldn’t figure it out till we had a third expert standing in front of the plane. It was caused by the canopy twisting a bit.
Vans says the compression force is 460N and expansion force is 300N, in pounds thats 103# / 67#. Mine measures 36# left and 45# right. The weakness is probably allowing the canopy to twist when lowering causing it to scrape. Interestingly Vans is cheapest on these struts at $20 each.
When I'm parked in my hanger I leave the canopy open to try to extend the life of the struts. I have replaced them due to not holding the canopy up that well especially if there is a strong breeze.
I had a distinct click that turned into an interference when opening my canopy. Discovered that the canopy frame aft of the hinge bolt was catching on the avionics cowl. Took a fair bit of “shrinking” the cowl skin to eliminate the bulge caused by forcing the canopy open.
I replaced both cylinders. The new ones were about twice the strength. The clicking is gone and the canopy is much better balanced.
There is a 3D printable canopy "hold-open" or you could use PVC pipe and notch out to do the same.
Refer to Post #8
With lifters that have the proper strength the wind isn’t a problem.
Just a suggestion. My lifters are still fairly new and have proper strength but I'm not walking away from my -12 without one of these in place. If you're okay with building a new canopy and not flying during the time it takes to make the new canopy that's up to you. But if I don't have a hand on the canopy one of these is in place.
How about when it’s windy not walking away from your plane with the canopy open, then there is no issue. 😂
As stated before......do as you wish. It was merely a suggestion that I wrongly thought might be helpful.
Amadeus,
I’m sorry your feelings are hurt. The OP, me started this thread with the question on how to test the strength of the cylinders because there was a click closing the canopy. You derailed the conversion wanting to discuss the wind closing the canopy, and the importance of using a stick to hold it open. Please understand my frustration.
Don't worry yourself over my feelings; no hurt here. The internet offers many places to encounter %*$#$ but it always surprises me to find them here......especially when offering help.
